I believe those honeycombs are there to straighten out the air or something like that so that the MAF sensor has an accurate reading. Not 100% sure on that tho. But I think that's also the same reason why K&N had some kind of flap in their intake pipe.
I believe you are correct. Hopefully removing it won't cause erroneous readings.
#3 | |
2ZR swap. DO IT! Ask how!
https://www.justanswer.com/toyota/4m...-throttle.html https://www.spyderchat.com/threads/s...purpose.71002/ It's there for a reason, even if it's not publicly visible. =) |
#4 | |
| Successful 1ZZ Throttle Body Swap | rabbito | Performance Modifications | 34 | 10-15-2024 08:12 AM |
| For Sale: 1ZZ Throttle Body and 0.25" aluminum wheel spacers | m911gt | Items for Sale by private party | 6 | 04-25-2009 09:52 PM |
