Old 06-12-2020, 02:58 PM   #1
Zedicus
Drives: scion xb
super rad.
thanks
Originally Posted by xnamerxx View Post
Throw some 100 in it, you'll see a big difference. I also found it kind of interesting that with no cat the exhaust had no smell as well. Keep an eye on oil consumption though, getting the rings to seal at higher rpm's is a issue.
i am hoping that as this was a fairly low miles prius engine that i can flog it enough to get a good ring seal. overall i won't be cruising at 7000rpm so i am not too concerned. and we only have 91oct here unless i want to register and buy AV gas.
Originally Posted by CrankyOldMan View Post
Crazy!
Did you consider an electric power steering assist from a current gen Yaris? You'd have to add the wiring to power it and possibly fabricobble the mounts, as well as spoof the speedo sensor to deal with the speed-based assist level. On second thought, that seems like more hassle than it's worth. =)
i did, and went through that same thought process. really, an MR2 electric pump could be added too the Scion XB system and be nearly bolt on. however even that is more work than needed.
Zedicus is offline   Reply With Quote
Old 06-12-2020, 06:19 PM   #2
xnamerxx
0-60 in slow
xnamerxx's Avatar
Drives: light blue liftback
Originally Posted by Zedicus View Post
thanks
i am hoping that as this was a fairly low miles prius engine that i can flog it enough to get a good ring seal. overall i won't be cruising at 7000rpm so i am not too concerned. and we only have 91oct here unless i want to register and buy AV gas..
Its more to do with how low tension the prius C engine rings are, its just something to keep an eye on didn't seem to hurt power all that much. On 91 it would still hit the knock sensor so 100 made that not happen, a whole lot more torque midrange between the two. Don't run avgas its got lead in it and it'll cause problems with your O2 sensors. If you're in Kansas try running 93 if you can find it.
2014 BSpec Divisional Champion
Prius Piston swap in 1NZ (update pls) rabbito Performance Modifications 2 06-12-2016 10:18 PM
tooter's manifold adventure... tooter Performance Modifications 1465 07-31-2014 08:11 PM
Comparison Test: 2012 Toyota Yaris Vs. 2012 Toyota Prius c Yar Is Word Third Gen Yaris General Discussion 27 09-06-2012 11:37 PM
Like a PRIUS... BUY THE YARIS SEDAN......LOOK AT THIS>>>> jay cobbs General Yaris / Vitz Discussion 8 06-07-2012 01:44 PM
Toyota says don't call them Priuses -- call 'em the Prii Kal-El Off-topic / Other Cars / Everything else Discussions 7 02-22-2011 10:30 AM
