Old 06-29-2020, 02:51 PM   #1
Neinris
I like that. How much did you have to cut off each end?
It was a pretty good chunk, 3 inches maybe. I wished I kept the ends, I could have reused it to fill the end.
I bought the rear bumper skirt from eBay, it bolts directly to the stock bumper, just need to drill out the holes, which are marked on the inside, but I don’t see the listing anymore though.
Old 06-29-2020, 04:34 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
That looks great and seems to fit very well. Any chance of a side shot? Also, I'd like to know more about the holes that need to be drilled. Are the screws hidden or visible when installed? Too bad the listing is gone. Dang. How much was it if you don't mind my asking?
Old 06-29-2020, 07:58 PM   #3
Neinris
Here's the profile views. The rear bumper came with two rubber gaskets, a gray one and black one, I'm using the gray one.
I stalk Yarisugi's car, you can see what the rear bumper would look like if it's color matched.
https://www.yarisworld.com/forums/sh...&postcount=120
https://www.yarisworld.com/forums/sh...&postcount=130
I really like the look of the wheels that he ended up sticking with, DRAG DR27s, but they're 15X7 ET10, with 175/50s. I found a similar looking set of wheels, that's 16X8 ET25. I'm going with 195/50s.
Old 06-29-2020, 09:37 PM   #4
Neinris
That rear bumper skirt is from Toyota. I was worried at first on how to install the rear skirt, but if you remove your rear bumper, you'll see circle marks on the bottom inside, you drill those out. The bolts are hidden. It wasn't that expensive, $125 USD. I'll keep looking for it, I though I had it saved.
2008 Yaris Sedan front bumper cover purchase and shipping questions qian DIY / Maintenance / Service 0 12-18-2018 01:52 AM
DIY Front Lip Options? heeroyuy01195 Cosmetic Modifications (Exterior/Interior) 0 12-05-2010 12:55 AM
Cracked Front Bumper BassAssassin Wash, Wax, Detailing, Exterior Repairs 4 08-24-2009 10:54 AM
Body kit front bumper fitment Kenshin Cosmetic Modifications (Exterior/Interior) 4 04-14-2009 03:32 PM
FS: JDM Modellist II Front bumper & JDM LED tails DKN-YARIS Items for Sale by private party 7 11-09-2008 01:10 AM
