Old 07-02-2020, 11:46 AM   #1
cweg
Drives: 2007 Yaris Sedan
My Hack Solution
I had the same problem getting the axle out of the transmission. Lacking any proper prying/pulling tools, here was my final solution: I tied two cords (ropes) around the axle between the tulip and transmission for a balanced pull; threaded the cord through the axle hole in the rotor with the rotor mounted in place (if I were to repeat this, I would put something in to protect the cord from fraying); used a scissor jack to create tension in the cord, protecting the rotor and lug nuts with 2x4 blocks; tap on the tulip with a hammer. Pop! It was beautiful (after hours of frustration)!
cweg is offline   Reply With Quote
Old 07-02-2020, 07:10 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Please tell me you took a picture of this contraption. It sounds super pic-worthy!
Are you in the aviation industry? CWEG rang a bell. Also, welcome to yarisworld.
TRD Delrin Rear Axle Bushing Collars tmontague Wheels, Tires and Suspension Forum sponsored by The Tire Rack 4 12-15-2019 07:50 PM
Wheel bearing / Outer TRE / Control Arm replacement howto shepd DIY / Maintenance / Service 3 09-14-2015 04:20 PM
Request: Picture of the transmission end of passenger CV axle WildChild DIY / Maintenance / Service 2 06-16-2014 12:35 PM
Wheel Bearing Replacement (FRONT) justjesus DIY / Maintenance / Service 11 04-26-2014 07:38 PM
drive belt replacement and/or water pump replacement sociolog DIY / Maintenance / Service 9 02-10-2014 12:33 PM
