Lowing Springs vs Coilovers
I've been vacillating between coilovers and lowering springs for the past couple of weeks. I have a number of things that I plan to do to the car that will require some significant funds, so I'm inclined to take the cheaper route here. The stock handling with TRD rear sway bar is pretty good, but I want to go a bit lower; about 1" lower. I have no plans of tracking the car but would like a wee bit more cornering stability. I polled Trevor (tmontague) and appreciate his advice, which is basically that if I'm not tracking my car and just want a bit of an improvement in handling, plus my 1" drop, go for the lowering springs and aftermarket dampers. Hope you don't mind me paraphrasing you, Trevor.
Anyway, here are some pics of my current setup. I realized a day or two ago, that I can't lower the car much more than an inch or I'll be getting close to my turbo drain hose. I'm optimistic that the Eibach Pro Kit (assuming I can get my hands on them, been having a little trouble contacting the outfit) 1" drop will allow me lower the car without contact with the car body under all driving conditions. ![]() ![]() Rear ![]() Rear ![]() Rear ![]() Front ![]() Front
Just bit the bullet. Ordered a set of Eibach springs from Tunershop. We shall see if it goes through. They're coming from Germany, seemingly unavailable in the USA or Canada. I'll have to borrow a set of spring compressors from our school shop.
Which damper set are you going with? That's the nice thing about (quality) coilovers. They're usually valved/matched for their intended spring rates.
#4 | |
Yesterday, I spoke with a Canadian outfit and got lots of info on this coilover set. They seemed to know their stuff and recommended a custom spring rate based on the fact that my car is a hatch as opposed to a sedan. Although they don't sell Fortune Auto coilovers, they will eventually become a certified dealer. They suggested Fortune Auto coilovers as an alternative. I was rather surprised that they'd recommend the purchase of someone else's product. https://racingcoiloverscanada.com/pr...8c9e504c&_ss=r
![]() ![]() ![]() Drives: Starlet Join Date: Nov 2017
Damn. Should have looked into the Bilstein B12 kit. Comes with B8 shocks and Eibach springs. I threw them in my car and have been pretty happy with them.
However, now I wish I had of gone the B14 coilover kit as I want the car a little lower. |
#6 | |
http://garage16.ca/bilstein/bilstein...i-2444199.aspx
Yeah, I wish I'd gone those now.
Jason@SportsCar put some in his daily according to this thread https://www.yarisworld.com/forums/sh...postcount=1302 *edit* based on that price in your link, it'd nearly be cheaper to buy them out of the UK as well. |
#8 | |
Here is another coilover possibility. I read several reviews and these seemingly pretty good.
https://www.tdotperformance.ca/hsd-h...itz-ncp91.html
Yes, the picture on the site was just a generic picture.
Point taken about adjustability. However, even with my other car that has fully adjustable coilovers, I've only tweaked things to the point that I'm happy with and then set and forget. I'd hypothesis that if the shocks are overall better quality with better matched valving and spring rates, they'd perform and feel better than a cheaper adjustable coilover. In saying that, I've not looked into HSD, nor do I know whether they are any chop for daily driving :) |
#11 | |
I just got the anticipated email from TunerShop Germany. They won't have stock of the Eibachs until 22 July. I cancelled, so am now, again, looking. A little disappointing though it may ultimately be for the best. I watched a few videos on the HSD coilovers and they do seem to be good quality. I'll be doing more research.
The deal is done. I bought this coilover set, but for $849.00 CAD from another outfit. Shipping is $110.00. $1083.00 all in. I hope I've made the right decision. I read many 'testimonials' and watched videos. Apparently it's a very 'streetable' set.
https://www.tdotperformance.ca/hsd-h...itz-ncp91.html Obviously, this is a generic pic:
![]() ![]() ![]() ![]() Drives: No longer own a yaris :( Join Date: Mar 2012
Nice! Do they come with all the mounts or do you need to re-use anything from the stock struts?
I'm a hermit named Lee |
#14 | |
Here are some pics of the car as it is. I think a 1" drop to start will be good. I may have to use a heat gun on the plastic front inner fender liner edge. Fortunately the plastic liner which extends inward can be easily moulded upwards. I'm pretty sure the tires will completely clear the quarter panel wheel well edges. ![]() ![]() ![]() ![]() ![]()
#15 |
Makes sense. I think a 1 inch drop will look fantastic and provide a good handling improvement.
#16 |
I think you shouldn't rub with a 1" drop. I didn't rub with Tein S.Tech springs on OEM dampers, and those drop the car a lot. But then again, I wasn't running wide tires. lol
#17 |
I think so too, Leegamer.
#18 |
Yeah, I hope it won't rub. This is part of the reason I went with coilovers. More adjustability. Even if I don't get a full 1" drop, I will get better handling.
| WTB Coilovers or lowering springs and rear sway bar | 07liftback | Willing to Buy by private party | 0 | 08-18-2017 03:14 AM |
| Want to trade Subs with amp and tein stech springs for coilovers! | NaviLupets | Willing to Buy by private party | 0 | 11-06-2013 12:36 AM |
| lowering springs + adjustable coilovers | Golddeenoh | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 7 | 05-20-2013 11:36 AM |
| FT: Tokico Blues + Tein S Tech Springs for Coilovers Plus Cash | DeathBeard | Items for Sale by private party | 0 | 11-02-2012 05:01 PM |
| New springs for Megan coilovers? | Thirty-Nine | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 18 | 02-10-2010 09:59 PM |
