![]() ![]() Drives: 06 Yaris RS MT Join Date: Jun 2018
You definitely need to do some logging to see what's really going on. The bucking seems to be a fuel delivery issue, but I'm far from an expert, the logging would help you figure it out, without it it's all guessing...
Yes I've read fried banzai's blog, great info... He says that closed loop tuning is not easy and that you have to disconnect the battery often so your LTFT don't affect your tune. When I'll have some tuning experience, I'll be able to shim in more. And how much of a difference between the OEM sensor and your wideband? I'm hoping I can tune with only the OEM sensor. |
#2 | |
My wideband and OBD2 are, on average, one full point off. For example if the aftermarket wideband (Prosport Pro gauge, with Bosch 4.9 sensor) reads 14.7, the OBD2 (via Torque) will read close to 13.8.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| my echo turbo build log | ipwnr | Forced Induction Forum | 26 | 07-14-2015 10:09 AM |
| Turbo build - stage 1:D | abstractmethod | Forced Induction Forum | 21 | 03-13-2014 08:04 AM |
| Want to build costom turbo kit. Need advice from boosted guys! | pimp my yaris | Forced Induction Forum | 639 | 09-28-2013 11:26 AM |
| Hyundai Turbo Veloster 150kw | *MAD DOG* | Off-topic / Other Cars / Everything else Discussions | 6 | 01-09-2012 11:35 PM |
