Old 07-13-2020, 12:19 PM   #1
tmontague
tmontague's Avatar
There likely would he no benefit for you for a lower temp tstat. IMHO there is no benefit to any situation for a lower temp tstat. Once you are above the 185F rating of the OEM tstat it is fully open anyways. All a lower rated tstat is going to do it make it harder to get up to operating temp when you are doing anything other tuen driving spirited on a hot day.
What is your concern with temps around 200F? Trying to bring them down will drop efficiency of the engine.
I've tried to wrap my head around why low temp tstat are even in the market and I've failed to find a reason why. I get the full removal of a tstat in a race car (to maximize coolant flow) but not for a lower rated temp tstat.
Old 07-13-2020, 02:00 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Sounds like solid info. Not too worried about temps overall. I haven't pushed it really hard in hot weather, so not sure how hot it would get. In many ways I'm all about reserve capacity, but it does sound like the stock cooling system has enough of that. Thanks again.
Need 07 Sedan Tail Light wiring info ASAP atebit General Yaris / Vitz Discussion 3 09-07-2013 06:48 PM
Swap sedan tach into liftback GrassrootsMS DIY / Maintenance / Service 17 09-26-2007 09:45 AM
thinking about buying the sedan. is it worth the extra money for the s(optB) version? friedbbq General Yaris / Vitz Discussion 14 05-20-2006 12:53 PM
