Old 07-25-2020, 03:34 PM   #1
Pinchlite
Drives: 2007 yaris HB
remove condensor-compressor...
So removing these items totally,then storeing them would ruin them?
What if any advantages would removing be.
Basically I dont like how the condensor is basically ontop/infront of the engine radiator.
I would think nothing infront of the engine radiator would allow it to get much more air and cool off better.
P.S I forgot to put this back in.
I suppone it directs air onto rad,
It sits to the left of radiator..
https://i.imgur.com/YFIRCsG.jpg
Old 07-25-2020, 10:34 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
No, if you remove the parts and store them, they would be fine. If left on the car, they would get mositure in them. I had an old Dodge van which were known for rear evaporator failure. A leak in it resulted in mositure making it's way all the way to my compressor, causing it to literally seize. I would minimally cover the compressor high side and low side ports with plugs if storing it. I agree that removing the condensor would allow more air through the rad.
Minimal advantages to removing the A/C components would be weight reduction, less parasitic draw on the engine from the compressor, even when freewheeling, a little more space in the engine bay for air flow. You would however have to find a shorter belt. It may not be worth the effort to remove the stuff.
I removed that plastic cover and used the space for a transmission cooler. I wouldn't sweat it, but it may keep your engine bay cleaner with it reinstalled. It is a bit tricky to reinstall without removing the bumper cover if I recall correctly. One of the plastic push pins is up under the crossmember, I think. It's been a while.
ImportRacer88's Photo Scavenger Hunt ImportRacer88 General Yaris / Vitz Discussion 8 02-28-2012 04:19 AM
Jerkratt - Photo Scavenger Hunt Jerkratt Photo-Video-Media Gallery 3 03-04-2009 09:03 AM
Custom Lftback - Photo-Scavenger Hunt custom Lftback Photo-Video-Media Gallery 2 03-01-2009 11:12 PM
