Old 07-31-2020, 09:23 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Maybe this?
https://parts.toyota.com/p/Toyota_20...724160320.html
https://parts.toyota.com/a/Toyota_20...1470-7701.html
Possibly P/N 7724160320
Old 08-01-2020, 04:52 PM   #2
ThrowingChicken
Drives: 2007 Toyota Yaris
This is the closest I've gotten to it so far, but I think that is for the smaller yellow clip that holds the fuel line.
ThrowingChicken is offline   Reply With Quote
Old 08-01-2020, 06:48 PM   #3
06YarisRS
Could it be part of this assembly?
https://parts.toyota.com/p/Toyota_20...720952101.html
If it's not, could you not find a piece of suitable diameter wire/soft bendable aluminum rod or such and make a "U" shaped clip. I assume the clip is designed to keep the hose from backing off under pressure? Then again, you don't want fuel spewing around under your back seat.
Old 08-01-2020, 06:52 PM   #4
ThrowingChicken
If it is, it would probably be part of this one. The illustration/product photos are almost no help, unfortunately.
https://parts.toyota.com/p/Toyota_20...740452050.html
Old 08-01-2020, 06:57 PM   #5
06YarisRS
Ah, I must have been looking at the wrong hose. Well, looks like you're getting closer anyway. And, yeah, the part sketches pretty much suck.
Yaris 2007 (UK bought) Key Fob replacement sdfsdfsd General Yaris / Vitz Discussion 4 01-25-2016 05:44 PM
Toyota unveils 2007 Yaris T-Sport Concept VitzBoy General Yaris / Vitz Discussion 63 01-21-2007 03:12 PM
