Old 08-04-2020, 07:51 AM   #1
dmac07
Drives: Yaris
@CTScott" Not sure if you can help with this request, but if you can then it opens up tons more Yaris's to your Cruise Control mod. @"hamdoen" bought a USDM ecu and successfully swapped it into an Asian market version. I also bought a USDM ECU (part no: 89661-52E90) and plan replace my Australian market version if this ac issue gets resolved
looks like mentions isn't implemented. I will PM him
dmac07 is offline   Reply With Quote
Old 08-04-2020, 07:21 PM   #2
hamdoen
Drives: Yaris Sedan 2007
yeah I think CTScott might have a solution. unfortunately he is no longer active in this forum.
So you want to replace your ECM too? Take a look at the AC amplifier in your car, maybe it's just like USDM. Or take a look to the pin out of the ECM. In Vios there is black wire in pin 18 A21 and red wire in pin 30 A21 of the ECM. I did'n find that wire in the USDM Yaris electrical wiring diagram.
in Vios AC amplifiers, there are 2 wire that go directly to the ECM pin 18 and 30 A21 harness which control idle rpm when the AC is active. This is different from the USDM version whose idle rpm is set via 2 wire that pass through the CAN line
anyway, what is your VIN number?
hamdoen is offline   Reply With Quote
Super weird Yaris 2003 A/C problem zoharby DIY / Maintenance / Service 13 06-22-2017 11:14 AM
Toyota Yaris Optimal RPM for Highways Anquietas General Yaris / Vitz Discussion 12 04-28-2017 05:59 AM
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 04:00 PM
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 RPM JEFF Great Lakes 0 09-24-2012 04:40 PM
IL: Chicago - Haunted RPM Car/Bike Show - October 20th, 2012 RPM JEFF Mid-Atlantic 0 09-24-2012 03:10 PM
