You have the read out, so you know (or can figure out) how to put the shim in. Watch some youtube videos on installing them. It'll save you some money by installing it yourself.
For sure. I assume shims are generic? Will investigate. Thanks!
| No factory rear alignment gear? | bad | DIY / Maintenance / Service | 6 | 01-28-2015 12:21 PM |
| Alignment Question | gsf1200m | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 2 | 10-16-2009 10:35 AM |
| WOW What a difference an alignment makes!! | YarisSedan | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 1 | 10-12-2009 05:29 PM |
| understeer | DOMAV | General Yaris / Vitz Discussion | 31 | 09-30-2009 07:01 AM |
