![]() ![]() Drives: Yaris 2016 1.3 Manual Join Date: Jun 2017
Hi @bronsin Di you solve your rad fan issue running slow? Or you changed with new motor?
Mine has the opposite it always run high speed no matter what and lost the low speed. I got the gen 3 yaris. I tested the fan relay no.1 and found okay, even swapped it with horn relay which is exact same part number. I tested fan relay no.2 and found okay too. I removed the resistor and tested it and got 1.3ohms which is what the spec should be... I was left with the Pressure Switch but when i tested it also found it to work fine. Then i remembered, i did an evaporator change about 6 months ago and the mechanic added some oil too during R134a recharge. I was thinking the mechanic may have overfilled my AC system with some refrigerant and ND-8 oil, he didn't use a weighing scale but only had the gauge manifold and touching of the LP pipe. This led me to vent a little of the refrigerant containing lots of oils (not allowed in U.S.) and there goes my Low Speed Fan kicking and when my engine is hot it uses the High Speed. |
| Hubcap question 2009 Yaris Sedan- URGENT | mrs_yaris | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 3 | 04-13-2016 02:21 PM |
| License Plate question | awebb005 | Cosmetic Modifications (Exterior/Interior) | 5 | 11-11-2014 08:28 AM |
| Voltage regulator and Amperage question... | cr.chango | DIY / Maintenance / Service | 13 | 11-24-2009 12:59 PM |
| ctrl-alt-delete question & free anti-virus question | Shroomster | Off-topic / Other Cars / Everything else Discussions | 18 | 09-08-2009 03:57 AM |
| Amplifier Watt Question....noob question | hasher22 | In Car Entertainment + Electronics (audio / video / alarm) | 4 | 09-27-2007 03:59 PM |
