#19 |
![]() ![]() ![]() Drives: 2017 VW Jetta 1.4L Manual Join Date: Feb 2009
Mobil 1 Extended Performance 5w-30 synthetic motor oil.
#20 |
![]() ![]() ![]() Drives: 08 Sedan Join Date: Oct 2008
#21 |
iQ innovator & researcher
Drives: 2012 iQ Join Date: Mar 2016
Liqui-Moly 0w-20
#22 |
#23 |
![]() ![]() ![]() ![]() ![]() Drives: 2014 Yaris SE Join Date: Apr 2014
#24 |
![]() ![]() Drives: 01 Yaris TS Join Date: Jan 2017
Dino oil breaks down and leaves sticky gunky residue
#25 |
![]() Drives: 2017 Toyota Yaris S XP-150 Join Date: Jun 2016
I use Royal Purple Full Synthetic 10w-30 on my 1NZ-FE
#26 |
![]() ![]() Drives: 2009 yaris Join Date: Feb 2016
#27 |
![]() Drives: Echo RS Join Date: Aug 2006
Liqui Moly, 5W30 Molygen
#28 |
![]() ![]() ![]() Drives: Charcoal 2012 Yaris SE 5 Speed Join Date: May 2016
Im use different full synthetic in my car, last oil change I put amsoil signature in it.
#29 |
![]() Drives: Great Wall Motors Voleex C20R Join Date: Jun 2020
My Great Wall 1NZ clone won an 800 mile endurance race with Walmart SuperTech Full Synthetic 10W-30. Going to send a sample to Blackstone.
#30 | |
Interesting info here, but I'm not certain that it applies to the 1NZ as well. Funny observations about global warming/climate change, but nonetheless an 'official' appearing document. ![]()
#31 |
![]() Drives: 2007 1.3L AWD (auto) Vitz 5 dr Join Date: Aug 2020
I'm interested in why and how you can say this. Every oil, dino or synthetic, has a lifespan does it not? So if you change out dino lube on schedule ie: before it fails, why should it not be OK? Even dino oil has detergents and agents in it that are the developments of research and chemistry.
And BTW: I for one won't put an all synthetic oil into an older engine that has been running dino all it's life. I've seen the proof of how old gaskets can begin weeping, and I've read why it happens. But that's just me with the evidence on the garage floor. YMMV. |
#32 | |
I have not shared the same leaking experience as you when switching from exclusively conventional to synthetic. The only leaks I've had likely would have occurred regardless of what oil was in the sump.
#33 |
My favorite oil is ace hardware motor or regularly 499 a quart but on sale usually in June and July for $1.99.
If you read those oil analysis it’s got the same thing as any other Motor oil
#34 | |
PQIA is a site I like. https://pqia.org/
#35 |
![]() ![]() ![]() ![]() Drives: 2009 Yaris--3dr MT Join Date: Jan 2011
I just put Pennzoil Ultra Platinum FS 5w30 in this last time. Got it on Amazon for around $23. I'm thinking seriously though about putting SuperTech FS 5w30 in next time and just sticking with that one long-term. That stuff is around $14 here. Having the oil changed regularly like I do, I imagine these FS oils are all about the same and getting the cheapest one available is the way to go.
#36 |
![]() Drives: 2003 Toyota Yaris Join Date: Jul 2020
I mostly use Total Quartz Ineo ECS 5W-30 because its What is recommended for our Citroen C4 Cactus and it’s not too expensive either.
| Zage Turbo Kit Install - Toyota Yaris | Focus_Sh1ft | Forced Induction Forum | 160 | 02-06-2022 08:14 PM |
| Yaris Oil Change DIY | rningonfumes | DIY / Maintenance / Service | 91 | 01-11-2019 07:18 PM |
| ***The Engine Oil Bible*** | Hussain-Vtec | Performance Modifications | 20 | 09-28-2016 02:47 PM |
| A Mystery Oi'll Say! | Yar Is Word | Fuel Economy Forum | 16 | 05-11-2013 04:22 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
