Gen 3 > Gen 2
Drives: NCP131, F-150, Focus ZTS Join Date: Jul 2019
I don't think ZZ and ZR engines share bellhousing bolt patterns. I may be incorrect though on that.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2002 Ford Focus ZTS 5 speed 2013 Rav4 LE AWD Autotragic - Wife's
No, I don't think they are either. I didn't even know that the 2ZR had ever been mated to a 6-speed manual. Assumed they were all 5-speeds.
#3 | |
The 2zr-fe engine swap guide Cranky's 2ZR-FE swap My 2zrfe swap Here is Tom's thread on the 6 speed conversion... 6 speed swap project Hope it helps! |
#4 | |
I think the title in the link below is incorrect http://https://usedjdmengine.com/toyota/2zz-6speed-trans/9074
#5 | ||
![]() Drives: XP 90 Join Date: Aug 2020
Hi all, let me start by thanking everyone for the replies so far, this is a great community and I'm glad to be part of it
So if I'm not mistaken the 1NZ in the 1.5L I4? This is another model that is very uncommon where I'm from, but the 2NZ-FE, being the 1.3 I4, is commonish around here and I believe that the guys in Mighty Car Mods bolted that transmission straight on without modification? If I could get this gearbox, driveshafts and hubs I should be set? Quote:
Sorry, I should have been clearer, at this time I'm just looking for any compatible transmission available from my limited selection. I'm not looking for a 6 speed right away, maybe in the future if I can source a EC63 and associated running gear I might consider it as I believe the Yaris TS came with this stock, but again, not sure, Thanks again to everyone here, great stuff from all particularly CrankyOldMan who's encouragement made me start this project, JD |
| 3rd gen 2zr swap with 6 speed | stidnam | Performance Modifications | 97 | 06-29-2021 04:59 AM |
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 11:56 AM |
| 06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) | 06YarisRS | Performance Modifications | 448 | 12-06-2018 08:12 PM |
| Problem help | MickZEL | DIY / Maintenance / Service | 38 | 08-01-2011 02:52 PM |
