![]() ![]() ![]() ![]() ![]() Drives: it is kinda stock Join Date: Oct 2010
hello all , kinda a general question here but didn't want to start a new thread , my question is if you are running an oil catch can with a turbo does it make sense to have a crankcase vent ? or will it even do anything
#2 | |
https://www.yarisworld.com/forums/sh...her#post824972
#3 | |
photo is not of my engine bay
#4 | |
Do you have any additional info and pics of your setup?
#5 | |
#6 | |
I doubt you'd ever feel any difference. Have you emptied you catch can yet to see what's in it? I have the hardest time remembering to empty mine. I actually remembered last week. I have a ball valve drain on mine. I emptied what would be probably 1/8 of the full volume of the can. It looked like the typical chocolate milk color and stinky as usual. I probably had driven 1500 kms. Not a lot, but much better than having it sucked back into my manifold, weakening my effective octane rating. I don't think you'll see any benefit to running higher octane (premium) gas. As far as I know, your engine is naturally aspirated with a compression ratio under 10:1.
#7 | |
| Oil catch tank question | window_lee | General Yaris / Vitz Discussion | 1 | 07-14-2009 08:04 AM |
| Synth Blend Oils | scape | DIY / Maintenance / Service | 7 | 07-12-2009 01:55 PM |
| perrin oil catch can | staypuft | Performance Modifications | 3 | 11-16-2008 12:20 AM |
| Motor oil debate - interesting info but a long read. | mikeukrainetz | General Yaris / Vitz Discussion | 6 | 12-10-2006 08:16 PM |
