Old 10-10-2020, 07:06 AM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by matthewai View Post
I see I see, so I've also seen those ones that screw on in place of the oil fill cap and they have a one way check valve ball, now I was understanding that you only want the air to be able to escape the crankcase not be sucked in through the vent. and I guess my original thought was since im running the oil catch can it adds more lines, seals, and connections where gasses could potentially escape, so im just trying to figure out if I should add the crankcase vent so any vapor would exit through that instead of some other part failing. even though im confident with the install and have seen no leaks
photo is not of my engine bay
Yeah, at one point I thought I had it all figured out, but it's been a while, so I forget the reasons. I can't remember all the logic I used to determine that I needed one. However, as mentioned in the link provided, when I plugged the vent hose, vacuum increased to the point where the engine was going to stall. I toyed with re-routing the exit of my oil catch can back into my pre-throttle body charge pipe. In my research, I found many varying opinions, some suggesting that I should completely cap off/eliminate the PCV system. I am now running well, with reasonable fuel trims, so I don't plan on messing with my current configuration.
Do you have any additional info and pics of your setup?
Old 10-10-2020, 08:50 AM   #2
matthewai
matthewai's Avatar
Drives: it is kinda stock
its stock right now (k&n drop in) I added the catch can about a month ago just because I think its a good idea to keep the engine cleaner. havent noticed any difference but I dont even know what id be looking for or "feeling" for by how it drives or uses gas . I usually put the mid octane fuel in but maybe I should be running the highest octane ? yes its not a Yaris ahhh sorry
Old 10-10-2020, 08:03 PM   #3
06YarisRS
Elantra N-Line?
I doubt you'd ever feel any difference. Have you emptied you catch can yet to see what's in it? I have the hardest time remembering to empty mine. I actually remembered last week. I have a ball valve drain on mine. I emptied what would be probably 1/8 of the full volume of the can. It looked like the typical chocolate milk color and stinky as usual. I probably had driven 1500 kms. Not a lot, but much better than having it sucked back into my manifold, weakening my effective octane rating.
I don't think you'll see any benefit to running higher octane (premium) gas. As far as I know, your engine is naturally aspirated with a compression ratio under 10:1.
Old 10-10-2020, 10:05 PM   #4
matthewai
matthewai's Avatar
Elantra N-Line?
have not emptied it yet and yeah i dont think id ever notice any difference either i guess i just like the idea of taking measures to keep the engine cleaner if possible
Old 10-10-2020, 10:29 PM   #5
06YarisRS
Oh yeah, for sure. I think they are a great idea. Keeping that crap out of your intake can only be good for the engine. Why not post up a pic of what comes out of the can? It would be cool to compare.
Old 10-14-2020, 06:32 AM   #6
matthewai
matthewai's Avatar
deff more than I thought it was gonna be so thats good, only installed for about a month of normal driving , I've only drove it hard a few times cuz its a new car. I've heard putting stainless steel wool in the bottom of the can helps to collect oil but this can does have a 2 stage baffle so I dont know if the wool is necessary.
Oil catch tank question window_lee General Yaris / Vitz Discussion 1 07-14-2009 08:04 AM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
perrin oil catch can staypuft Performance Modifications 3 11-16-2008 12:20 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
