Old 10-10-2020, 08:03 PM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by matthewai View Post
its stock right now (k&n drop in) I added the catch can about a month ago just because I think its a good idea to keep the engine cleaner. havent noticed any difference but I dont even know what id be looking for or "feeling" for by how it drives or uses gas . I usually put the mid octane fuel in but maybe I should be running the highest octane ? yes its not a Yaris ahhh sorry
Elantra N-Line?
I doubt you'd ever feel any difference. Have you emptied you catch can yet to see what's in it? I have the hardest time remembering to empty mine. I actually remembered last week. I have a ball valve drain on mine. I emptied what would be probably 1/8 of the full volume of the can. It looked like the typical chocolate milk color and stinky as usual. I probably had driven 1500 kms. Not a lot, but much better than having it sucked back into my manifold, weakening my effective octane rating.
I don't think you'll see any benefit to running higher octane (premium) gas. As far as I know, your engine is naturally aspirated with a compression ratio under 10:1.
Old 10-10-2020, 10:05 PM   #2
matthewai
matthewai's Avatar
Drives: it is kinda stock
Elantra N-Line?
have not emptied it yet and yeah i dont think id ever notice any difference either i guess i just like the idea of taking measures to keep the engine cleaner if possible
Old 10-10-2020, 10:29 PM   #3
06YarisRS
Oh yeah, for sure. I think they are a great idea. Keeping that crap out of your intake can only be good for the engine. Why not post up a pic of what comes out of the can? It would be cool to compare.
Old 10-14-2020, 06:32 AM   #4
matthewai
matthewai's Avatar
deff more than I thought it was gonna be so thats good, only installed for about a month of normal driving , I've only drove it hard a few times cuz its a new car. I've heard putting stainless steel wool in the bottom of the can helps to collect oil but this can does have a 2 stage baffle so I dont know if the wool is necessary.
Oil catch tank question window_lee General Yaris / Vitz Discussion 1 07-14-2009 08:04 AM
Synth Blend Oils scape DIY / Maintenance / Service 7 07-12-2009 01:55 PM
perrin oil catch can staypuft Performance Modifications 3 11-16-2008 12:20 AM
Motor oil debate - interesting info but a long read. mikeukrainetz General Yaris / Vitz Discussion 6 12-10-2006 08:16 PM
