Old 10-11-2020, 01:04 AM   #1
zoidberg444
zoidberg444's Avatar
I had some odd electrical gremlins when my alternator went bad - not as bad as yours but it was quite obvious the electrical system was experiencing a voltage drop. My voltage regulator was on the way out. This manifested in lights dimming and the engine acting strangely. I have seen plenty of videos on YouTube of mechanics in the US complaining most of the re-man parts like alternators and starters sold by the autoparts store are basically junk. I would probably find a genuine Toyota one from a scrapyard or order the Denso brand replacement.
If its not that - something this weird will probably be a ground issue or some wires shorted together somewhere - I would probably start looking through the wiring diagrams trying to find what they all have in common. These sorts of issues really are a pig to fix and you will probably end up having to have a professional diagnose it.
- Yaris 2006, 1.0, 5 door hatchback "Betty" - 240,000 miles
UK to Nordkapp in a Yaris
Old 10-11-2020, 06:25 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
I suppose it could be a poorly remanufactured alternator. I've actually had great luck in the past with remans. I often buy older vehicles and the 3 - 4 alternators that I've replaced in the past decade have held up well. The last two, I bought from Carquest (the Canadian arm of Advance Auto Parts, I think) have been great. They told me they have a lifetime warranty. Many parts stores have alternator testing benches. The OP should be able to confirm whether it's good or bad fairly easily. I would get that tested and if it's good, do exactly what you say - start looking at the wiring schematics.
Electrical Problems PS,A/C,RADIO,SPEEDOMETER,SIGNALS,AIR BAG LIGHT ON, ALTERNATOR toystory DIY / Maintenance / Service 43 04-17-2021 04:54 AM
Electrical Problems Tommy8030 DIY / Maintenance / Service 4 03-09-2016 06:44 PM
09 Yaris Electrical Problems (P/S, ABS, AC, Speedo, Blinkers, Wipers Not Functioning) garrettbeachy DIY / Maintenance / Service 2 08-20-2015 01:19 PM
Car electrical gone crazy bitz767 General Yaris / Vitz Discussion 13 01-27-2013 09:38 AM
Starter (or possibly electrical) Problems with 2008 Yaris Sedan amandadalton DIY / Maintenance / Service 6 11-21-2012 05:32 PM
