Old 10-13-2020, 06:35 PM   #1
JCPepper
Drives: 2008 Yaris Hatchback Automatic
Well, the mechanic I took it to misdiagnosed it as a bad replacement alternator and replaced it. He then called me back and said it was acting the same and that he is checking the drive pulley on the crank to see if it is slipping, which is laughable because it obviously wasn't when I put in the first replacement alternator and the car would be making noise if this were true.
The guy told me this and said he'd call back in an hour...3 hours later ... no call. So, I called him and got no answer. Don't know how this will play out but I'm getting angry. This car is my livelihood, I drive UberEats for a living. It's already cost me 2 grand in parts and lost wages not including what this mechanic might take me for.
My best educated guess is that it is a short at the blower motor resistor pack. The blower motor was the first thing to stop working, and the resistor pack looked like brown corrosion was on the bottom. It was hard to see because I was using a mirror.
I was on my way to get an angled screwdriver and multimeter to remove and check the resistor when it died. Should have had them tow the thing back to my place, I might have it fixed by now.
JCPepper is offline   Reply With Quote
Old 10-13-2020, 06:47 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Ah, very frustrating. I can empathize. If you decide to do some electrical testing, I may have some wiring diagrams if you need them.
Electrical Problems PS,A/C,RADIO,SPEEDOMETER,SIGNALS,AIR BAG LIGHT ON, ALTERNATOR toystory DIY / Maintenance / Service 43 04-17-2021 04:54 AM
Electrical Problems Tommy8030 DIY / Maintenance / Service 4 03-09-2016 06:44 PM
09 Yaris Electrical Problems (P/S, ABS, AC, Speedo, Blinkers, Wipers Not Functioning) garrettbeachy DIY / Maintenance / Service 2 08-20-2015 01:19 PM
Car electrical gone crazy bitz767 General Yaris / Vitz Discussion 13 01-27-2013 09:38 AM
Starter (or possibly electrical) Problems with 2008 Yaris Sedan amandadalton DIY / Maintenance / Service 6 11-21-2012 05:32 PM
