![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
Opening tail lights...
I would imagine opening rear lights would be the same as opening any other plastic headlight assembly>
I want to open the tails and install flexible led tubes for this effect... https://i.imgur.com/wh8QgZi.jpg I already opened up the spec D and replaced the Halos so I am quite confident I can do the rears. I was just curious if they might be permanently glued vs Butyl? Pic of my diy specd halo upgrade. https://i.imgur.com/dPfU9hA.jpg |
#2 | |
#3 | |
Gen 3 > Gen 2
Drives: NCP131, F-150 Join Date: Jul 2019
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2013 Rav4 LE AWD Autotragic - Wife's
#4 | |
#5 | |
Gen 3 > Gen 2
Here is a shot of my 2014's retrofit. I basically blacked out the housing except for the chrome trim pieces and turn signal reflector. I deleted the amber reflector too. I would like to eventually do a set off M-LED projectors in a factory set of Japanese market housings, but those projectors are $500CAD for the pair, oof. ![]()
![]() Drives: 5D YR 2012 Auto Join Date: Aug 2020
#7 | |
night
I only replaced the halo rings and swapped bulbs to led. |
Haha I ordered some of that the other day. I plan on resealing one of my headlamps again and properly cause I don't want any condensation or anything happening.
I used an giant cardbox box and hair dryer as a makeshift oven so I'm sure it'll work with the butyl rubber great to reseal. |
| 3rd Gen Vitz RS (and G's) Tail Lights: Part Numbers, Ordering, and Installation | keiri | Third Gen Yaris General Discussion | 26 | 09-04-2020 01:01 AM |
| Yaris 2007 tail lights change to TS VERSION HELP | Roberto Borges | General Yaris / Vitz Discussion | 2 | 04-07-2019 03:54 PM |
| Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal | V70R_Blackbrick | Cosmetic Modifications (Exterior/Interior) | 26 | 11-27-2013 11:14 PM |
| LED tail lights installed | Cutie Pie #2 | Cosmetic Modifications (Exterior/Interior) | 10 | 08-21-2012 12:25 AM |
| Tail lights for 09 sedan | piepie | Cosmetic Modifications (Exterior/Interior) | 7 | 06-03-2009 10:24 AM |
