Old 10-25-2020, 12:18 AM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by mitch9521 View Post
Pretty much all aftermarket projector lights have crappy output. Only option is a projector retrofit or retrofit a set of stock housings. I did a D2S 3.0" retrofit in my 2014 with DEPO stock style lights. Turned out awesome.
I think a projector upgrade might be in my future. I've surfed around looking at bits and pieces. Something about putting my OE headlights into my oven freaks me out. LOL. I though about it again, as a local u-Pull sells headlights for like $40.00 a piece. Suppose I could buy a set and try. If I do, I'll hit you up for some tips.
Old 10-25-2020, 10:34 PM   #2
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
I have personally done 5 retrofits, 2011 Ranger, 2013 F150(twice), 1999 Tercel, 2007 F150, 2014 Yaris. Its not that bad. I will say though, my Gen 3 headlights were held together with permaseal and it was a NIGHTMARE to pull them apart. If I remember right it took 6 attempts per headlight at about 250°F.
Here is a shot of my 2014's retrofit. I basically blacked out the housing except for the chrome trim pieces and turn signal reflector. I deleted the amber reflector too. I would like to eventually do a set off M-LED projectors in a factory set of Japanese market housings, but those projectors are $500CAD for the pair, oof.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
Old 10-29-2020, 03:31 AM   #3
spoonzz
Drives: 5D YR 2012 Auto
What did you use to reseal it? The same permaseal or new one?
spoonzz is offline   Reply With Quote
Old 10-29-2020, 06:39 AM   #4
Pinchlite
Drives: 2007 yaris HB
opened the (spec d ) headlight housing using heat gun.
This went way easier then I thought it would.
I used same original seal..but put bead of silicone into groove,,pressed together and let sit for a few days.
so far no leaks.
have driven in heavy rain on highway and even powerwashed car multiple times.
No leaks or fogging up.
Pinchlite is offline   Reply With Quote
Old 10-29-2020, 11:36 PM   #5
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Hell no. The standard for re-sealing headlights in the retrofit community is butyl rubber. The same stuff you'd use for sealing windshields and stuff, older cars run butyl as headlight sealant too.
I did my 1999 Tercel's headlights and they were butyl sealed, they literally fell apart when I pulled on them after heating them up to ~200°F for 5 minutes, absolutely brilliant.
2014 NCP131 5 Speed
3rd Gen Vitz RS (and G's) Tail Lights: Part Numbers, Ordering, and Installation keiri Third Gen Yaris General Discussion 26 09-04-2020 12:01 AM
Yaris 2007 tail lights change to TS VERSION HELP Roberto Borges General Yaris / Vitz Discussion 2 04-07-2019 02:54 PM
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 10:14 PM
LED tail lights installed Cutie Pie #2 Cosmetic Modifications (Exterior/Interior) 10 08-20-2012 11:25 PM
Tail lights for 09 sedan piepie Cosmetic Modifications (Exterior/Interior) 7 06-03-2009 09:24 AM
