#1 | |
Gen 3 > Gen 2
Drives: NCP131, F-150, Focus ZTS Join Date: Jul 2019
Here is a shot of my 2014's retrofit. I basically blacked out the housing except for the chrome trim pieces and turn signal reflector. I deleted the amber reflector too. I would like to eventually do a set off M-LED projectors in a factory set of Japanese market housings, but those projectors are $500CAD for the pair, oof. ![]()
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2002 Ford Focus ZTS 5 speed 2013 Rav4 LE AWD Autotragic - Wife's
![]() Drives: 5D YR 2012 Auto Join Date: Aug 2020
![]() ![]() ![]() ![]() Drives: 2007 yaris HB Join Date: Mar 2016
opened the (spec d ) headlight housing using heat gun.
This went way easier then I thought it would. I used same original seal..but put bead of silicone into groove,,pressed together and let sit for a few days. so far no leaks. have driven in heavy rain on highway and even powerwashed car multiple times. No leaks or fogging up. |
Gen 3 > Gen 2
Hell no. The standard for re-sealing headlights in the retrofit community is butyl rubber. The same stuff you'd use for sealing windshields and stuff, older cars run butyl as headlight sealant too.
I did my 1999 Tercel's headlights and they were butyl sealed, they literally fell apart when I pulled on them after heating them up to ~200°F for 5 minutes, absolutely brilliant.
| 3rd Gen Vitz RS (and G's) Tail Lights: Part Numbers, Ordering, and Installation | keiri | Third Gen Yaris General Discussion | 26 | 09-04-2020 12:01 AM |
| Yaris 2007 tail lights change to TS VERSION HELP | Roberto Borges | General Yaris / Vitz Discussion | 2 | 04-07-2019 02:54 PM |
| Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal | V70R_Blackbrick | Cosmetic Modifications (Exterior/Interior) | 26 | 11-27-2013 10:14 PM |
| LED tail lights installed | Cutie Pie #2 | Cosmetic Modifications (Exterior/Interior) | 10 | 08-20-2012 11:25 PM |
| Tail lights for 09 sedan | piepie | Cosmetic Modifications (Exterior/Interior) | 7 | 06-03-2009 09:24 AM |
