![]() Drives: yaris 2015 Join Date: Mar 2016
2nz-fe engine
Yaris 2016
Engine: 2nz-fe 1299mL This engine is installed used since when? I read somewhere that its since 2005/2006 same engine... True? Nothing changed? Same quality too? Cuz i see older Yaris’s still run smooth & like a clock... & My ride is around 210,000km & im starting to here sounds in the engine... Even though i drive normal or slow(mostly) Is there a better & longlife & economic.. toyota/lexus engine that I could install in my car? Even if its old? I heard a 91s camry engine can take a beating & run like a clock... Or other suggestions? No plans on selling it incase its a suggestion... |
#2 | |
![]() ![]() Drives: Yaris 2016 1.3 Manual Join Date: Jun 2017
what is your issue? i have same 2nz-fe in my yaris 2016 and we are both in saudi. i think mine has the single VVTI. the new yaris 2017 above uses different engine with dual VVTI. mine is at 106k KM now after 4 yrs of use... runs like bnew... can barely notice engine sound when the AC is off. just did normal maintenance by full syn 5w30 lube oil changes every 8-10k km and plug changes every 20k km... never had a problem except for the evaporator which had a premature failure (pinhole leak at 3yrs 1 month).. aside from that everything runs smooth... i regularly cleaned my throttle body every year. |
| T Montague's 2zr swap - '08 m/t sedan some extra info | tmontague | Performance Modifications | 285 | 04-20-2021 11:56 AM |
| Yaris verso engine swap | Decieved | Performance Modifications | 3 | 06-10-2015 08:51 PM |
| ***How to Choose an Exhaust System*** | Hussain-Vtec | Performance Modifications | 16 | 03-16-2014 08:02 AM |
| Remote Engine Start PT398-33070 | Reeves360 | In Car Entertainment + Electronics (audio / video / alarm) | 3 | 08-26-2009 07:11 PM |
