Old 11-02-2020, 04:53 PM   #1
Desircustoms
Drives: 06 Yaris RS MT
Awesome! I look forward to a pic of your MAF map. Thanks!
I actually think I might have a leak somewhere, maybe that's why I have to crank the voltage higher than you. And we also have different engines.
My car is always stalling when idling ever since the cold started... Will post more on my thread whenever I figure it out.
Desircustoms is offline   Reply With Quote
Old 11-05-2020, 05:55 AM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Sorry to hear that man. Do you have leak testing stuff? I had idle stalling before I installed a resistor on the crankshaft sensor wiring, but my stalling occurred when the engine was at operating temp.
Old 11-05-2020, 04:42 PM   #3
Desircustoms
Thanks I will try the resistor soon, it might be the culprit, as I had crank sensor code came up once or twice throughout the summer.
I double checked and tighten all the clamps. I tried swapping spark plugs, shortened the gap to .03" and it still dies at operating temps. It must be fic related because it still does it after I zero'd all the maps, and the car was running fine before I wired the fic.
Old 11-05-2020, 05:45 PM   #4
06YarisRS
Yeah, I found out about this fix on the Scion forums. The theory is that the F/IC is overly sensitive to the somewhat 'dirty' signal from the stock sensor. Apparently, the 2.2Kohm resistor bridging the crank sensor + and - wires cured problems for many, but not for everyone. I think that the experimentation that resulted in a cure was designed to address mid range RPM bucking, but a side effect was improved idling. Unless, it was purely a coincidence, my car's idle issues completely disappeared when I installed the resistor. I can't remember the wattage rating of the resistor, but I think it was 1/4 watt or something like that. I actually bought a pack of 8 or 10. I could mail you a couple, free of charge of course, but it would probably be easier and quicker for you to pop into an electronics store and grab a few.
Old 11-05-2020, 09:44 PM   #5
Desircustoms
I found a 2.2k resistor in my electronic stuff, soldered between crank magi- and +. It fired up, got to temperature, and it stalled while idling, a bit after i revved it a couple times.
I read somewhere that you didn't wire the cam magi?
Old 11-06-2020, 12:42 AM   #6
06YarisRS
Sorry to hear that it stalled. Dang. No, I did not put a resistor on the cams. I didn't even wire the cams into the F/IC. Did you wire your VVTi into the F/IC? I see you're running PVC tubing for your vacuum lines. I don't suppose that's collapsing under high vacuum at idle? Probably not, as it would likely cause problems right away as opposed to only when at temperature. Could the tubing be getting softer at operating temps? Not sure if vacuum itself is related to temp or not. I know that when I installed my catch can, I used rubber transmission hose or similar and it sucked flat under vacuum. I had to replace it with hydraulic hose, probably because I used a larger - more likely to collapse - diameter tubing. Just a thought.
AEM FIC fight for turbo!!! thatbryanguy Forced Induction Forum 135 08-14-2015 08:22 PM
FS: AEM FIC / TRUE BOOST GAUGE / CONTROLLER TOLMACH Items for Sale by private party 12 11-07-2013 11:12 PM
Question about how to load file to AEM FIC? DKN-YARIS Forced Induction Forum 24 06-01-2013 09:58 PM
FS: Zage Turbo kit, AEM FIC with Pnp Harness djgab101 Items for Sale by private party 32 04-11-2013 10:42 AM
AEM FIC tuning experience thatbryanguy Performance Modifications 0 09-03-2012 01:29 PM
