![]() ![]() Drives: 06 Yaris RS MT Join Date: Jun 2018
I found a 2.2k resistor in my electronic stuff, soldered between crank magi- and +. It fired up, got to temperature, and it stalled while idling, a bit after i revved it a couple times.
I read somewhere that you didn't wire the cam magi? |
Sorry to hear that it stalled. Dang. No, I did not put a resistor on the cams. I didn't even wire the cams into the F/IC. Did you wire your VVTi into the F/IC? I see you're running PVC tubing for your vacuum lines. I don't suppose that's collapsing under high vacuum at idle? Probably not, as it would likely cause problems right away as opposed to only when at temperature. Could the tubing be getting softer at operating temps? Not sure if vacuum itself is related to temp or not. I know that when I installed my catch can, I used rubber transmission hose or similar and it sucked flat under vacuum. I had to replace it with hydraulic hose, probably because I used a larger - more likely to collapse - diameter tubing. Just a thought.
2006 Yaris 5 Door RS 2ZR-FE (2011 Corolla 1.8L) Swapped, Automatic, T-28 Turbocharged (8 psi), HSD MonoPro Coilovers, DIY W/M Injection, custom 3" cold air intake, custom 2.5" exhaust, TRD rear sway bar, Penguin Garage 13mm spacers (rear), custom Civic front lip, full repaint, Android 6.0 7" touchscreen, Rockford Fosgate speakers, tweeters, NVX underseat subwoofer https://www.instagram.com/2zr_turbo_yarisrs/ Last edited by 06YarisRS; 11-06-2020 at 12:52 AM. |
| AEM FIC fight for turbo!!! | thatbryanguy | Forced Induction Forum | 135 | 08-14-2015 08:22 PM |
| FS: AEM FIC / TRUE BOOST GAUGE / CONTROLLER | TOLMACH | Items for Sale by private party | 12 | 11-07-2013 11:12 PM |
| Question about how to load file to AEM FIC? | DKN-YARIS | Forced Induction Forum | 24 | 06-01-2013 09:58 PM |
| FS: Zage Turbo kit, AEM FIC with Pnp Harness | djgab101 | Items for Sale by private party | 32 | 04-11-2013 10:42 AM |
| AEM FIC tuning experience | thatbryanguy | Performance Modifications | 0 | 09-03-2012 01:29 PM |
