Old 11-06-2020, 01:42 AM   #1
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
Originally Posted by Desircustoms View Post
I found a 2.2k resistor in my electronic stuff, soldered between crank magi- and +. It fired up, got to temperature, and it stalled while idling, a bit after i revved it a couple times.
I read somewhere that you didn't wire the cam magi?
Sorry to hear that it stalled. Dang. No, I did not put a resistor on the cams. I didn't even wire the cams into the F/IC. Did you wire your VVTi into the F/IC? I see you're running PVC tubing for your vacuum lines. I don't suppose that's collapsing under high vacuum at idle? Probably not, as it would likely cause problems right away as opposed to only when at temperature. Could the tubing be getting softer at operating temps? Not sure if vacuum itself is related to temp or not. I know that when I installed my catch can, I used rubber transmission hose or similar and it sucked flat under vacuum. I had to replace it with hydraulic hose, probably because I used a larger - more likely to collapse - diameter tubing. Just a thought.
AEM FIC fight for turbo!!! thatbryanguy Forced Induction Forum 135 08-14-2015 09:22 PM
FS: AEM FIC / TRUE BOOST GAUGE / CONTROLLER TOLMACH Items for Sale by private party 12 11-08-2013 12:12 AM
Question about how to load file to AEM FIC? DKN-YARIS Forced Induction Forum 24 06-01-2013 10:58 PM
FS: Zage Turbo kit, AEM FIC with Pnp Harness djgab101 Items for Sale by private party 32 04-11-2013 11:42 AM
AEM FIC tuning experience thatbryanguy Performance Modifications 0 09-03-2012 02:29 PM
