Old 11-17-2020, 02:54 PM   #1
bronsin
bronsin's Avatar
I tried to get the oil filter off yesterday but it was too tight. Got the truck up on ramps though which was good. There is an air dam I have to remove someday to 17 mm bolts.
Made an appointment for Friday morning at the local Sunoco station to remove the oil filter and put the one I got from Amazon on. They’ve done stuff like this for me before when I couldn’t do it.
Old 11-17-2020, 05:23 PM   #2
06YarisRS
Drives: 06 2ZR Turbo Yaris RS
What kind of oil filter wrench are you using? Band-type, plier-type, socket-type?
