Old 01-08-2021, 08:23 AM   #1
nortonfb
Drives: 2007
Belt slipping
nortonfb is offline   Reply With Quote
Old 01-08-2021, 11:24 AM   #2
ThinkPad
Drives: Yaris XP9 1.3 '06
Originally Posted by nortonfb View Post
Belt slipping
Sounds plausible, as the belt was squealing a little bit a few weeks ago when the A/C compressor got engaged.
I will loosen the tension on the belt so i can rotate the pulleys etc. by hand to check them. And if those seem ok i will tighten the belt again.
ThinkPad is offline   Reply With Quote
Yaris Cold start problem vinny121 DIY / Maintenance / Service 12 05-09-2011 10:36 AM
chirp/squeak noise just off idle when cold tadc DIY / Maintenance / Service 14 02-20-2011 03:09 PM
RPM in park when on cold start? jabranko General Yaris / Vitz Discussion 4 01-04-2011 09:45 PM
Transmission designed for 10-15 min cold start delay Ironwill5 DIY / Maintenance / Service 29 12-03-2009 08:08 PM
longer turn over on start w/ cold weather manborn General Yaris / Vitz Discussion 20 02-04-2007 11:35 PM
