![]() Drives: Yaris 2009 Hatchback Join Date: Jan 2017
Watch this video: https://m.youtube.com/watch?v=l_lkE6dndfg
It worked for me. |
#2 | |
![]() ![]() ![]() Drives: Yaris manufactured after 2007 Join Date: Nov 2010
I watched that video and it is a good video. Here is another video that looks pretty good How to fix the most common water leak in the trunk or back of your car that says most water in a trunk (or boot) is from the tail lights. But he has a regular trunk, not have a hatchback. He uses something called Lexel as a sealant. I also have wet carpet in front of the rear (passenger) seats, especially wet on the right side. QUESTION: Would leaking around the tail lights cause wetness of the carpet in front of the rear seats? This is a critical question for me, since I really have to solve this problem to keep mildew from occurring. The problem of water in the trunk (or boot) can be solved temporarily by pulling the plug and letting the water out. But I also want to see if I can solve water in the trunk permanently, maybe by sealing the rear tail lights. R. |
#3 | |
When you remove the tail lights you will easily see where the water is coming from by looking at the rusty trail going down from certain holes.The sticky 3M stuff shown in the video is sold at Advance Auto Parts but you can probably also use something similar from Home Depot and such. |
#4 | |
QUESTION: Could the tail light assembly be removed if necessary with all that Windo-Weld in place all around the edge of the assembly (similar to what is seen in the video)? I am wondering the same thing if silicone rubber cement were used instead of the Windo-Weld. It might be hard to remove the tail light assembly if necessary, because you can't necessarily get to the "gasket" that you've made with a knife to start to free up the seal. Anybody have any opinions about this? Thanks, R. |
#5 | |
I tried(and failed) to remove the back seat to do some sound deadening and not because of the water leak.The water on my back seat carpet wasn't that much. |
| Tags |
| spare tire, water leak |
| 08 Yaris water leak troubleshooting help requested | 2bz | DIY / Maintenance / Service | 5 | 12-22-2018 05:37 PM |
| What do you have jammed in your hatchbacks spare tire storage compartment? | jayeh | Off-topic / Other Cars / Everything else Discussions | 4 | 12-24-2017 09:58 PM |
| Red Angel Stop Leak - Need Advice | Boba Ben | DIY / Maintenance / Service | 2 | 07-20-2017 09:36 PM |
| The thread with the single, hidden sub over spare tire? | IsLNdbOi | In Car Entertainment + Electronics (audio / video / alarm) | 43 | 07-17-2009 01:21 AM |
| The Tire inflation debate... | Tankota | General Yaris / Vitz Discussion | 20 | 06-01-2006 07:09 PM |
