Old 01-18-2021, 10:43 PM   #1
momoivanoff
Drives: Yaris 2009 Hatchback
That's a security torx and it's not a T,it's an E and I most likely to be an E10 as I said.I doubt that Toyota have used a different size on the 2008 base model.
momoivanoff is offline   Reply With Quote
Old 01-18-2021, 11:25 PM   #2
RMcG
Drives: Yaris manufactured after 2007
Thanks Ivanoff,
I am just groping for the terminology so I can buy the right wrench to unloosen the bolt. There is a picture of a similar bolt at belmetric.com that seems to be referred to as having an "external torx drive" and the size is E10. So apparently the head of the bolt is referred to as a "drive."
The diameter of the threaded part of this "bolt" appears to be 10 mm. The diameter of the head of the bolt I got by measuring was about 11/32 = 8.7 mm, which is close to the 10 mm of the threaded part of the "bolt." So that is consistent with an external torx drive that is size E10.
So it looks like you are right. So what size & type of wrench would I need? I put PB Blaster penetrating oil on the bolt heads today.
Thanks,
R.
RMcG is offline   Reply With Quote
Tags
instructions, rear, removal, seat
Consumer Reports not too pleased with Yaris Befuddled General Yaris / Vitz Discussion 132 02-28-2011 02:57 PM
Yaris from New Zealand model - some differences to Canadian RS Yaris model Super_BQ General Yaris / Vitz Discussion 0 07-23-2007 02:54 AM
Yaris HB base model availability... AutoTech1 General Yaris / Vitz Discussion 11 05-01-2006 10:44 PM
