Old 05-30-2012, 10:02 AM   #73
pennyracer
boydstir
pennyracer's Avatar
Drives: 08 yaris liftback
Send a message via AIM to pennyracer Send a message via Yahoo to pennyracer
now with a little on the car with header installed the exhaust hanger right by the cat is now squeaking big time have lubed it and then purchased a new one same problem to much motor movement in gear at a stop maybe someone could make a bolt on bracket to prevent this i would pay someone for this bolt on mod i may try to make one myself but really don't have the tools for that is there anyone here that has put on a header on a automatic yaris and had the extra exhaust movement causing major squealing at times ?
pennyracer is offline   Reply With Quote
Old 05-30-2012, 11:09 AM   #74
tooter
play every day
tooter's Avatar
Drives: 2012 Yaris L 2dr 5sp
Are you sure the sound is coming from the hanger and not from within the joint itself? If the excess flange is not ground off right to the surface of the donut just like the stock manifold...
...there would be metal to metal contact between the header and the downpipe which could possibly be making the noise.
Old 05-30-2012, 11:35 AM   #75
pennyracer
boydstir
pennyracer's Avatar
the collector side end piece of pipe is almost flush with the flange gasket when i lubed the hanger post it went away for a little bit so i am pretty sure that's ware the squeaking is coming from and i don't think the header totally bottoms out in the exhaust flange when tightened up but that noise would be a good match metal on metal
Old 05-30-2012, 11:38 AM   #76
pennyracer
boydstir
pennyracer's Avatar
as much as i dont care for megan it does have the support bracket built onto flange. but im not sure the header deal is all that for me .
Old 06-24-2012, 07:30 PM   #77
tooter
play every day
tooter's Avatar
Also try listing it in the for sale by owner section. If I recall, someone here was looking for one just a little while ago.
Old 06-24-2012, 07:54 PM   #78
tk-421
tk-421's Avatar
Drives: 5D-07-LB
I was thinking of selling my W*R, but this review is making me think twice.
I'm still wondering if I should wait for an exhaust swap before putting it on the car, though...
Old 06-24-2012, 08:09 PM   #79
tooter
play every day
tooter's Avatar
I'll be running a dyno test with the Weapon R header, an axle back exhaust, and a Weapon R intake soon, and will post the results. Maybe that will help you to decide.
I'm more of a hypermiler style driver as opposed to an agressive top end power driver, so the header fits my low end needs. In 900 miles the accelerator has been to the floor 3 times just to see what it's like.
Old 06-24-2012, 08:24 PM   #80
tk-421
tk-421's Avatar
Drives: 5D-07-LB
Looking forward to the results!
I'm not opposed to saving gas for most of my driving, but I do like to have the option to step on it if I ever need to.
(Or at least that's what I tell myself...)
Old 06-24-2012, 10:05 PM   #81
When I drive it's backwards of that.
Old 01-13-2021, 12:37 AM   #82
Mr. Li
Drives: 2007 Yaris
i just installed few days ago, I'm wondering is the gap between header and center section normal? because its leaking while accelerating?
Mr. Li is offline   Reply With Quote
Old 01-28-2021, 02:09 AM   #83
Neinris
Drives: 08 Yaris 3 Door Hatchback
If you read post #7, the OP said it's 3/8" too long, so he had to trim it down.
Neinris is offline   Reply With Quote
DC Sports Header install and evaluation Loren Performance Modifications 217 07-04-2017 07:40 AM
weapon R header aucorium Yaris TS Talk 18 10-10-2012 12:37 PM
Megan Racing header install and review with pics. Herbicidal Performance Modifications 6 09-03-2009 09:40 AM
Pre Hack Revival: Megan Racing Header vs Ebay Header Sabretooth Performance Modifications 15 08-19-2009 06:26 PM
Weapon R header noise? bladesmith6 Performance Modifications 4 10-20-2008 08:09 PM
