Old 02-02-2021, 06:40 AM   #1
komichal
General advice is - when you want to drive somewhere and the car is incredibly hot and even hotter inside - to open all doors and let the wind and nature cool the inside as much as possible. After a minute or two you can start the AC and let the air circulate internally - only after a few minutes (when the vents actually start blowing the cool air and the internal space starts to cool off) you can consider switching to external air.
The AC unit in Yaris is quite weak I must say. The dealership checked the coolant, the pressures, the compressor - everything OK. But it takes ages in hot summer to cool the internal space. I wonder if the more southern regions received some more powerful AC because in hot days in Central Europe the AC is almost insufficient.
Yaris Oil Change DIY rningonfumes DIY / Maintenance / Service 91 01-11-2019 07:18 PM
NST crank pulley, K&N Filter, heat position control and inner fender Adriaan Items for Sale by private party 2 11-28-2015 08:04 PM
Car shuts off when A/C turned on... Howster DIY / Maintenance / Service 33 07-06-2013 05:00 PM
Beware WIX Filter #51394 zkay DIY / Maintenance / Service 19 12-22-2012 12:09 AM
