Old 02-08-2021, 12:32 AM   #1
rayfloyd170
Drives: Yaris 2016 1.3 Manual
Make sure you got the right belt tension... I experienced changing to a new belt and the same sound, in my case it was never the belt at all. When it is loose it will squeal, also when it is overtightened... You should be in the right tension. Other than that if there is still squealing then maybe there could be some other issues (alternator bearing, AC compressor, waterpump) . You can also test this by removing the belt and running the engine for a "short period" just to determine if it is really coming from these components.
rayfloyd170 is offline   Reply With Quote
Old 02-08-2021, 07:42 AM   #2
Leegamer
Leegamer's Avatar
There is no belt tensioner on the car, you just adjust the alternator.
I'm a hermit named Lee
2008, belt, squeal
