Old 02-15-2021, 03:01 PM   #1
RomanDave
Drives: 2NZ ITB NCP10
Originally Posted by kevinj93 View Post
All the gain seems to be from about 4500 RPM up. I very rarely see revs that high on my 2NZ-FE in normal road use, but more midrange would be nice. Anyone ever tried the 1NZ-FE inlet manifold and TB on a 2NZ?
It's a cylinder filling issue.
The reason it doesnt gain any power at lower rpm, is because in factory form the motor can already fill the cylinder with air very near 100% full.
Then you can only make so much torque from that much air/fuel pushing the piston down.
The only real options for low end or mid range power are forced induction or more displacement.
Or otherwise, changing the gearing can make an incredible difference.
Also when the motor doesnt completely fall over on its face when you rev it some more, it definitely changes your driving style a bit.
I've owned this car for 8 years completely 100% stock, since 30,000km old and I've always driven it like a complete nanna. As it doesnt want to rev, so you end up shifting short anyway.
But when that top end power is available, you use it!
More so when C56 is fitted :D
RomanDave is offline   Reply With Quote
Old 02-16-2021, 02:11 PM   #2
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
My 1NZ-FE is the same way, I shift it at 2000rpm most of the time when I'm casually driving. I'm in 5th by 60-65km/h.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
Adding Power Trunk Release Ideas...Need Help Jrilla DIY / Maintenance / Service 12 08-23-2009 02:38 PM
Plugs for power gains? lostmind Performance Modifications 8 07-25-2007 08:19 PM
adding power without any cost OxyG3nE Performance Modifications 13 04-24-2007 10:24 AM
