Old 02-16-2021, 02:11 PM   #1
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
Originally Posted by RomanDave View Post
It's a cylinder filling issue.
The reason it doesnt gain any power at lower rpm, is because in factory form the motor can already fill the cylinder with air very near 100% full.
Then you can only make so much torque from that much air/fuel pushing the piston down.
The only real options for low end or mid range power are forced induction or more displacement.
Or otherwise, changing the gearing can make an incredible difference.
Also when the motor doesnt completely fall over on its face when you rev it some more, it definitely changes your driving style a bit.
I've owned this car for 8 years completely 100% stock, since 30,000km old and I've always driven it like a complete nanna. As it doesnt want to rev, so you end up shifting short anyway.
But when that top end power is available, you use it!
More so when C56 is fitted :D
My 1NZ-FE is the same way, I shift it at 2000rpm most of the time when I'm casually driving. I'm in 5th by 60-65km/h.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Electrical System Upgrade Advice sqcomp In Car Entertainment + Electronics (audio / video / alarm) 6 03-23-2016 01:15 AM
Adding Power Trunk Release Ideas...Need Help Jrilla DIY / Maintenance / Service 12 08-23-2009 02:38 PM
Plugs for power gains? lostmind Performance Modifications 8 07-25-2007 08:19 PM
adding power without any cost OxyG3nE Performance Modifications 13 04-24-2007 10:24 AM
