Go Back   Toyota Yaris Forums - Ultimate Yaris Enthusiast Site > Second Generation Toyota Yaris Main Rooms > Regional Forums > Europe (continental)
Old 03-28-2021, 10:16 AM   #1
Our compressor has an internal clutch. Visually, it appears that the clutch is always engaged.
You need to get a pressure test done as a first step. If you're low, then you have a leak. If pressure is fine, then your next likely point of failure is the pressure sensor. Failure of that component is rare but is exactly what shut my a/c down.
Trouble with a/c vrg2016kr DIY / Maintenance / Service 2 07-03-2020 07:50 PM
A/C Not Blowing Cold Air...among other things yarisitis DIY / Maintenance / Service 38 07-28-2016 05:00 PM
DIY: Unlink A/C from Defroster stran DIY / Maintenance / Service 46 01-19-2015 10:17 PM
A/C Clutch Compressor question tmontague DIY / Maintenance / Service 3 05-11-2014 08:57 AM
