Old 04-03-2021, 10:14 AM   #1
Paavo Gopan
Drives: Toyota Yaris Mk2 Zinc 1.3
Engine started! None of the OBDII scanners worked so I had another look at the fuse box with someone a bit more mechanical literate and they found a fuse that was busted. I put in a spare fuse from the box and it started straight away... only to find a big crack in the radiator. I am still chuffed to bits.
Thank you again to everyone for the suggestions, not long now and she'll be back on the road.
Paavo Gopan is offline   Reply With Quote
The Intermittent Cranking No Start Yaris VVTi mystery continues. FASTTEC used. YarisVVTi2002 DIY / Maintenance / Service 2 09-16-2019 06:43 PM
DIY: Intake Installation redyaris DIY / Maintenance / Service 53 08-23-2014 06:34 AM
Toyota's new subcompact will use Mazda's Skyactiv engine Kal-El Off-topic / Other Cars / Everything else Discussions 43 03-25-2014 02:01 AM
A Mystery Oi'll Say! Yar Is Word Fuel Economy Forum 16 05-11-2013 05:22 AM
slight clutch kickback after engine start?? marcus DIY / Maintenance / Service 0 09-17-2010 12:05 PM
