Old 04-11-2021, 07:18 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Good points, Stidnam. I was actually having that problem with Toyodiy when looking for these part numbers in the cross reference box--some models returned didn't actually have that part number when you drill down into the diagram.
The other consideration for any ECU swap is wiring compatibility. Unless you go through pin-by-pin and identify all the signals on each ECU, it's not safe to assume that they're interchangeable. That's why we use the xD ECU here, it's basically only missing a few wires and everything is compatible. I've put dozens of hours into that kind of research for the 2ZR swap and I'm doing it again for the entire Yaris wiring system to be able to strip it down to the bare essentials for a race setup.
3rd gen 2zr swap with 6 speed stidnam Performance Modifications 97 06-29-2021 04:59 AM
T Montague's 2zr swap - '08 m/t sedan some extra info tmontague Performance Modifications 285 04-20-2021 11:56 AM
3rd gen engine swap, 2ZR? 2AR? Swap newbie m.flores.0928 Third Gen Yaris General Discussion 6 10-02-2020 10:54 AM
06YarisRS's 2ZR-FE Swap 5-Door Hatchback (Automatic Transmission) 06YarisRS Performance Modifications 448 12-06-2018 08:12 PM
2zr swap and e-test in Ontario tmontague Performance Modifications 7 12-23-2016 09:12 AM
