Old 05-06-2021, 09:23 PM   #1
stidnam
Drives: Starlet
@senioryaris: wrong spelling on my name bud. No assumptions made in my original question, just a question. An assumption would look something like the following: You've installed additional lighting and you no longer like the look of the DRLs in combination with the new lights you've installed.
Anyway, doesn't really matter. Try disconnecting pin 2 from the HL / DRL relay. Should be green and runs to the main body ecu. Controls the DRLs. Assuming it earths that relay point to turn them on.
Mind you though, if the DRL is always on by default and that trigger wire only dims the DRL, then might not work to eliminate them completely.
stidnam is offline   Reply With Quote
Old 05-07-2021, 07:18 PM   #2
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
Drives: NCP131, F-150, Focus ZTS
Pulling the hand brake disables the DRLs. however if you release it and then pull it back up while the car is running, the DRLs stay on regardless, its strange.
2014 NCP131 5 Speed
2007 F150 4.2L 5 Speed
2002 Ford Focus ZTS 5 speed
2013 Rav4 LE AWD Autotragic - Wife's
mitch9521 is offline   Reply With Quote
Old 05-07-2021, 08:27 PM   #3
stidnam
Drives: Starlet
The parking brake switch earths out a pin on the main body ecu, which is the same ECU that controls the DRLs. Must be some logic in that computer to trigger that under those specific conditions.
If you turn the headlights on, do the DRLs just DIM or do they go off completely?
It may be a case of needing to see how the DRLs are actually wired in the headlight units and disconnect from there.
Old 05-08-2021, 03:52 PM   #4
mitch9521
Gen 3 > Gen 2
mitch9521's Avatar
If I leave the parking brake up, the lights will go on and off. If I release the brake and pull it up again, the lights will just dim and brighten.
2014 NCP131 5 Speed
2018 yaris, canadian model, disabling, drl
Yaris Hatchback 2018 vs 2011-2013 tailgate difference? (for spoiler) bmg88 Cosmetic Modifications (Exterior/Interior) 4 12-13-2020 10:14 AM
Bought a new (for me) 2018 Yaros hatchback, I miss my 2013 Yaris SE Brunno One New YARIS Purchase Forum 0 07-07-2020 10:59 PM
Tein Street Basis Coilover Install - 2007 Canadian Yaris Sedan NCP93 Stock sheekeebut Wheels, Tires and Suspension Forum sponsored by The Tire Rack 0 06-13-2014 07:39 AM
