![]() Drives: 2019 Yaris LE hatchback Join Date: Aug 2019
Disabling DRL - 2018 Yaris (Canadian model)
Added Aux lights, want to disable DRL as it is no longer needed.
N.B. 2018 Yaris (Canadian model) Thanks for feedback, Adam |
![]() ![]() ![]() Drives: Starlet Join Date: Nov 2017
I'm intrigued. Why would anyone want to disable their DRLs given it's a safety feature?
I wish my car had DRLs |
![]() ![]() ![]() ![]() Drives: No longer own a yaris :( Join Date: Mar 2012
https://www.yarisworld.com/forums/showthread.php?t=894
Pretty likley it's the same for your car. Worth checking. I did this on my 2008
I'm a hermit named Lee |
@stidman: ADDED Aux lights... controlled by the ignition circuit... do not assume too much
@Leegamer: The design has apparently changed, according to the search on this forum STILL looking for a solution! |
#5 | |
Gen 3 > Gen 2
Drives: NCP131, F-150, Focus ZTS Join Date: Jul 2019
If someone has a gen 3 ECU pinout kicking around, I have a theory I wanna test.
2014 NCP131 5 Speed 2007 F150 4.2L 5 Speed 2002 Ford Focus ZTS 5 speed 2013 Rav4 LE AWD Autotragic - Wife's
@senioryaris: wrong spelling on my name bud. No assumptions made in my original question, just a question. An assumption would look something like the following: You've installed additional lighting and you no longer like the look of the DRLs in combination with the new lights you've installed.
Anyway, doesn't really matter. Try disconnecting pin 2 from the HL / DRL relay. Should be green and runs to the main body ecu. Controls the DRLs. Assuming it earths that relay point to turn them on. Mind you though, if the DRL is always on by default and that trigger wire only dims the DRL, then might not work to eliminate them completely. Last edited by stidnam; 05-06-2021 at 11:03 PM. |
#7 | |
Gen 3 > Gen 2
#8 | |
If you turn the headlights on, do the DRLs just DIM or do they go off completely? It may be a case of needing to see how the DRLs are actually wired in the headlight units and disconnect from there. |
#9 | |
Gen 3 > Gen 2
It'd be interesting to see how the DRL is actually wired in the headlight unit. The wiring diagram doesn't show any specific wiring for the DRL itself. It just shows the two HL units. The HL relay has 6 pins
- HLOR - low beam right - HLOL - low beam left - +B - receives power from the main head lamp fuse through the dim relay when the high beams are not powered - DRLS - goes to the main body ecu DRL - H - goes to the main body ecu HRLY - E - Earth I just don't know what's happening inside that relay. I would have ordinarily expected to see the DRLs themselves in the wiring diagram and some kind of resistor controlling the dim function of them...unless the DRLs are part of their own diagram somewhere. I'd still try disconnecting that DRLS wire if it were easy enough to do. |
Thank you guys for snooping how to disable DRLs on 3 gen Yaris.
Maybe one day we can find the solution... Lots of folks might benefit As for auxiliary lights I put on (which can serve as DRLs with lower power consumption & hopefully greater longevity), I highly recommend those. |
| Tags |
| 2018 yaris, canadian model, disabling, drl |
| Yaris Hatchback 2018 vs 2011-2013 tailgate difference? (for spoiler) | bmg88 | Cosmetic Modifications (Exterior/Interior) | 4 | 12-13-2020 10:14 AM |
| Bought a new (for me) 2018 Yaros hatchback, I miss my 2013 Yaris SE | Brunno One | New YARIS Purchase Forum | 0 | 07-07-2020 10:59 PM |
| Tein Street Basis Coilover Install - 2007 Canadian Yaris Sedan NCP93 Stock | sheekeebut | Wheels, Tires and Suspension Forum sponsored by The Tire Rack | 0 | 06-13-2014 07:39 AM |
