Old 05-13-2021, 11:45 AM   #1
speedworxs
Drives: |Mr2
Originally Posted by Neinris View Post
I actually follow that guy, and that's exactly why I brought the idea. I had thought of putting a 2AR-FE in my Yaris, but I hate the fact that the exhaust header would be next to the radiator, although I believe that it's feasible, and the subframe already has a channel for the exhaust pipe. I even thought of putting a 2GR, but that's just too much.
What makes the 2ZR-FXE have higher compression, is it just the pistons? If so, would it be possible to take a 2ZR-FXE's piston, mate it with the 3ZR-FAE's short block and use a 2ZR-FE's cylinder head? Is it too much work for only some gain?
What about just a 2ZR-FXE reverted to an FE for higher compression application? Supposedly the generally accepted gauge for adding compression is that one full point of compression can add between 3 to 4 percent power, so that's roughly 9-12%, so average 13HP gain.
the 2zr is going to be your best bet, if you like the way the yaris handles now, the weight increase will be very low
the pistons will be the compression increase if nothing else has changed - i recommend a short block and swap cams; thats the route i'm going with on my 1nz-fxe. then you don't have to resize anything (bearings, rings, and redo gaskets)
given the increase in power on the 2ar, i bet the 2zr could be a strong 40hp increase... but don't forget the 2ar in the video is using a tuned ecu, and you would need similar to make the best out of any engine
speedworxs is offline   Reply With Quote
Old 05-13-2021, 12:14 PM   #2
Neinris
Drives: 08 Yaris 3 Door Hatchback
Thank you! I appreciate the input. I do love how my Dee Dee handles, and I've even yet to put a rear sway bar and a front strut tower bar, so I can just imagine how much more it would improve. And actually you don't gain any weight from the 1NZ to 2ZR swap. I bet if you can lay 150+ WHP NA on this baby it would rock!
Neinris is offline   Reply With Quote
2018 Yaris SE 5MT - T-Sport w/Valvematic! atomic_hoji Performance Modifications 130 02-23-2019 11:56 AM
New Spark Plugs, Engine Light Appear grvdggr Performance Modifications 6 09-21-2015 09:34 AM
***How to Choose an Exhaust System*** Hussain-Vtec Performance Modifications 16 03-16-2014 08:02 AM
