Old 06-17-2021, 05:24 PM   #1
Zelands
Drives: Yaris
Originally Posted by Neinris View Post
Sounds like you're on the right track. See if you can locate the VVT-i solenoid and clean it, I believe it also has a filter. Parts/brake cleaner should be safe enough.
I checked the solenoid. It is not clogged, it switches immediately when I apply power from the battery.
Resistance seems to be within specification.
I wonder what the voltage coming from ECU should be. With ignition on, it is 6.4V. I have no idea is it as it should be or not.
As to mesh filter - it is there on the parts list, but for the life of me I cant find where it is. Some sources say that it does not have one at all.
I am getting more questions than answers :(
Zelands is offline   Reply With Quote
The Official "Bamboo the Yarisworld Traveler" Thread (v4, part 2) Darb Off-topic / Other Cars / Everything else Discussions 86 10-18-2017 09:03 AM
Strange OBD II code: C3201 CrankyOldMan DIY / Maintenance / Service 10 09-29-2015 10:58 PM
P0010 OBD engine Code crazylegs DIY / Maintenance / Service 1 08-27-2015 08:27 PM
full tank japle Fuel Economy Forum 15 12-10-2013 12:05 PM
