Old 06-18-2021, 12:43 AM   #1
iwanttobeamole
Drives: 2000 Yaris 1NZ-FE Supercharged
Originally Posted by CrankyOldMan View Post
Yep, went through a few pins and a few aluminum crank pulleys with the Blitz. The pin shearing off like that is intentional--don't replace it with a hardened/solid pin or you risk having to replace the whole crank next time.
Weird.. This has been together for 8 years making up to 1bar of boost (that's 14.5 barley corns for you americans) and it's been fine. I think it just came loose.
How much boost were you running through your blitz?
iwanttobeamole is offline   Reply With Quote
Old 06-18-2021, 09:58 AM   #2
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
HA! I love Matt Parker!
No more than 6 or 7 lbs, the Ogura compressor (TX-07) is only about 700cc/rev. The real damage was done by the magnetic clutch pulley turning on and off because there's no auto-tensioner to absorb the sudden change of tension on the belt. Here's a video of a high-performance car under acceleration that has one: https://youtu.be/5NnMuyifPA4
1nzfze, jimze, supercharged, supercharger
2NZ-FE Supercharged Limits iwanttobeamole Forced Induction Forum 8 11-21-2016 04:59 PM
1NZ-FE All Motor Build burned Performance Modifications 19 10-24-2014 10:56 AM
Supercharged 2nz-fe VVTI tuning iwanttobeamole Forced Induction Forum 2 09-02-2012 07:30 PM
++JIMZE SUPERCHARGER++ MANSETH Forced Induction Forum 17 07-07-2010 12:47 AM
