Old 06-22-2021, 07:20 PM   #1
vaironl
vaironl's Avatar
Drives: 2010 Yaris 3 door, manual tran
Originally Posted by Cletus Garfunkle View Post
I would say thats more than fine to run I'm using rotors and pads I got off of an echo at the junkyard 10k miles with no problems so far. If you look at drilled/slotted rotors they have indents that go farther into the rotor than that nick you have. Id say run them.
Thanks! I ended up hearing similar advice from another forum and put them on but I think I messed up the install or needed to clean up the parts a lot better than I did because my car is not coasting well and slows down a little. I’ll start the issue I’m having on another thread.
vaironl is offline   Reply With Quote
Compilation of Yaris How-tos/DIYs YarisBueller DIY / Maintenance / Service 39 04-28-2018 09:47 AM
Help: Rear Door Small Window Install nick.dollimount DIY / Maintenance / Service 7 09-22-2010 03:22 PM
Help: Rear Door Small Window Install nick.dollimount DIY / Maintenance / Service 0 07-31-2009 09:40 AM
First thoughts: Carbotech XP8 pads and slotted rotors jkuchta Wheels, Tires and Suspension Forum sponsored by The Tire Rack 37 12-19-2008 11:21 AM
