Old 06-29-2021, 10:26 AM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Looks like fun! Jason@SportsCar did some serious wizardry to his SCCA club racing 1NZ a few years ago when he took the national championship in H Production but nobody's been able to get their hands on the secret recipe for that one. ;) There are options for cams and manifolds than can potentially free up a few more horses but it's mostly trial and error to get the right design.
The 2ZR is the simplest engine upgrade and nets you at least 30 hp. I'm assuming you don't have an issue with fabricating your own mounts so a 1ZZ would be only slightly more mechanically complicated since there are no factory mounts for that swap. The electrical side isn't well documented so you'd be largely on your own--the 2ZR is just a few wires different from the 1NZ on the engine bay harness and the ECU mounts in the same location. The 2ZZ is way more potential but harder to source and likely much more expensive. I guess it just depends on how much you want to spend to get out in front of the GM crowd.
Take a look at the 2ZR swap threads to see what's involved, I'd be happy to answer whatever questions I can!
Old 06-30-2021, 01:47 PM   #2
jonny77
Drives: 2009 YarisS
Thanks for this info, I thought a 1ZZ Corolla would bolt right up. The bottom mount is on the tranny and there is only one mount on the front of the engine. I'm assuming that is the mount you're referring to for fabrication. I'll have to look into the 2ZR as I was leaning toward the 1ZZ. The 2ZZ is way too much for our class. Thanks so much!
jonny77 is offline   Reply With Quote
DIY - Sparco Race Seat Install Idjiit DIY / Maintenance / Service 16 08-14-2017 10:15 PM
Weird thing..my left wheel sits in more than the right ezhacker1 Cosmetic Modifications (Exterior/Interior) 33 06-21-2010 03:43 PM
Which friggin' transmission is in this thing? H3LlIoN Performance Modifications 19 08-20-2009 08:34 AM
Eibach Race Springs seth_man Wheels, Tires and Suspension Forum sponsored by The Tire Rack 5 11-07-2008 05:03 PM
YEAH YEAH...I Brought new HID for my baby!!!! iloveyarisRS Cosmetic Modifications (Exterior/Interior) 29 12-23-2006 03:27 PM
