Old 07-14-2021, 10:22 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Looks like you're on the right track with the stop switch--that's the only input into the Shift Lock ECU. Can you observe the solenoid when it fires and verify that it's fully retracting the blocking mechanism? It's possible that the click you're hearing is the solenoid firing but bottoming out, or the blocker arm is damaged and doesn't fully retract.
Here's the circuit from the repair manual.
2007 yaris hatch noisey clutch on ac compressor - changed 2007yarishatch DIY / Maintenance / Service 3 06-17-2020 07:12 PM
2007 Yaris hatch - thinking TRD Type-Y General Yaris / Vitz Discussion 18 01-18-2018 11:47 PM
stores water in cowl and wets lower exterior windhield at first driving 2007 hatch dogsridewith DIY / Maintenance / Service 2 07-21-2017 10:32 AM
Just bought 2007 Yaris hatch Lightrfire New YARIS Purchase Forum 5 02-19-2016 04:57 PM
Will not shift into park AlaskaYaris DIY / Maintenance / Service 7 02-19-2013 01:37 AM
