Old 08-26-2021, 11:56 PM   #1
Isaac1
A good rule of thumb is anything bigger than the size of a dime needs to by sprayed, and anything with rust needs sanding and prep with primer.
Isaac1 is offline   Reply With Quote
Old 08-27-2021, 01:23 AM   #2
RMcG
Drives: Yaris manufactured after 2007
Thanks Isaac,
Since there are two scratches, long and thin, is there anything like a "pen" for sanding to remove rust and a "pen" for applying primer? I know there are "pens" for applying touch up paint.
For the one "scratch" on the rear hatch, the bare metal/rust area is small, smaller than a dime. Is there anything that allows you to sand this limited area? Perhaps sand paper affixed somehow to a regular (non-Phillips head) screwdriver would work. Perhaps something like this scheme would allow sanding of the other scratches on the door and window frame.
Perhaps there are spray cans with tiny tubes in the nozzles like for WD40, see link .
Maybe I should just tape these areas with duct tape (for a tape that will protect against sanding), so that just a very small area around the scratches is exposed and then sand the exposed areas somehow. Then prime and touch up the scratches with brush or spray. On the other hand, the adhesive of the duct tape might be hard on the surrounding good paint & good finish, so maybe masking tape on the paint, with duct tape over the masking tape would be a better scheme.
Any comments from you or others will be appreciated.
Thanks,
R.
RMcG is offline   Reply With Quote
rust, scratches, touch, touch-up
Noobie Advice Needed ianmak UK 7 10-17-2017 02:00 PM
Advice on wheel spacers and sway bars needed! Lars Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 12-05-2013 11:28 AM
Yaris 06 T Spirit advice needed ! nocturne_sa General Yaris / Vitz Discussion 1 01-03-2010 05:24 AM
