Old 08-27-2021, 05:40 PM   #1
remcafee
definitely knock that rust off with a magic eraser or some fine sandpaper first, then glob on your touch up paint, then you can use running compound to smooth it out a little
Old 08-28-2021, 02:43 AM   #2
RMcG
Drives: Yaris manufactured after 2007
Thanks remcafee,
What grade sandpaper would you use? You mean rubbing compound, not running compound, don't you?
I looked at some information about using magic eraser to remove auto rust, and some people do use it successfully to remove auto rust. Thanks for the tip. I will investigate this more, as I want to use it correctly and intelligently and not damage the surrounding car finish.
Thanks again,
R.
RMcG is offline   Reply With Quote
rust, scratches, touch, touch-up
Noobie Advice Needed ianmak UK 7 10-17-2017 02:00 PM
Advice on wheel spacers and sway bars needed! Lars Wheels, Tires and Suspension Forum sponsored by The Tire Rack 16 12-05-2013 11:28 AM
Yaris 06 T Spirit advice needed ! nocturne_sa General Yaris / Vitz Discussion 1 01-03-2010 05:24 AM
