Old 09-04-2021, 04:02 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
Looks like everything in the fuse box under the bonnet is powered all the time.
If you're going to be doing electrical stuff on the car, an electrical meter is invaluable. Even a cheap battery powered one with an analog display or the free ones from Harbor Freight are fine for determining if there's power or not. That helps with chasing down electrical shorts and making sure your ground wires are actually grounded.
Old 09-04-2021, 08:22 PM   #2
YodaBird
Drives: Gray
Thanks for the info.
Free electrical meter from Harbor Freight ?
When there is a wire, which is suppose to connect to any metal in the car, I assume that metal can be around the fuse box as well ?
YodaBird is offline   Reply With Quote
Hydrodipped bezel, engine cover, fuse cover z0mb13k1ll Cosmetic Modifications (Exterior/Interior) 5 05-09-2016 10:39 PM
Fuse box Cover / Bin Craig W DIY / Maintenance / Service 2 02-08-2016 10:09 PM
Wtb driver side fuse cover bin and sun visor clips Creepin Willing to Buy by private party 3 02-07-2016 11:02 PM
Two amps one fuse? And hu install? FuuFuu In Car Entertainment + Electronics (audio / video / alarm) 4 12-24-2011 11:33 AM
Toyota Echo or Scion Xa/Xb for aftermarket HU receiver kit? ceboyd In Car Entertainment + Electronics (audio / video / alarm) 7 12-08-2006 02:13 PM
