Old 09-14-2021, 03:12 PM   #1
CrankyOldMan
2ZR swap. DO IT! Ask how!
CrankyOldMan's Avatar
As long as you're not breaking the connectors you're fine. ;) There's a black retaining lever thing that holds them in place and helps to pull them out.
Here's the layout of the junction block:
Old 09-14-2021, 03:59 PM   #2
tuppy
Drives: 2008 Yaris
Hi, thanks again for your help. I found a complete copy of the 2007 Yaris wiring diagram online and after studying it a bit was able to work out which connectors on the junction box I needed.
After disconnecting 4A and 4B and inserting a new fuse, I could turn the headlight switch on without blowing the fuse (though the headlights didn't work of course). Then I tried with just 4A connected without issue, and again with just 4B connected, which left me very confused. So I connected both again and the fuse still didn't blow. At this point I didn't have the bulbs in the taillight or license plate sockets, so I reinserted those, and they lit up just fine.
Before messing with the connectors I was looking at the taillight wiring again while talking about the problem with my father, and I noticed the wires going from the reverse/turn bulb assembly to the running light socket had all been pinched, and one had the tiniest bit of copper showing, no more than 1 or 2 millimeters. It didn't occur to me at first that this could be a short, because those wires are only a few inches long and run around foam padding on the taillight housing. But then I realized the taillight housing presses the foam against the metal body of the car.
Everything seems to be working now, and I was extra careful to keep those wires free when I put the taillight housings back on, with a generous amount of electrical tape over the tiny nick in the coating.
We had replaced one of those bulbs a month ago or so, and must have got the wires caught in between the body and the housing when we reinstalled it.
tuppy is offline   Reply With Quote
electrical, fuse blown
15A Fuse keeps blowing Gc01 DIY / Maintenance / Service 2 09-09-2020 09:35 PM
Heater fuse keeps blowing, interior fan is dead. phyrefighterjay DIY / Maintenance / Service 10 07-19-2015 07:18 AM
Fuse for tail lights melsplaine DIY / Maintenance / Service 2 09-26-2014 03:51 PM
Free Projectors or LED tails for 1 Yaris 4d + 1 Yaris 2d in SoCal V70R_Blackbrick Cosmetic Modifications (Exterior/Interior) 26 11-27-2013 10:14 PM
Dome fuse keeps blowing! watso4j UK 4 06-13-2011 05:08 PM
